Latest post 06-07-2010 3:40 PM by jolabari. 7 replies.
Page 1 of 1 (8 items)
  • 06-06-2010 3:07 PM
    How to watch PC in Link rooms
    Hello,
    I have my PC connected to my BV8-40 in the living room and would like to watch this in the Link room (Beocenter 6-23). I can watch all other outputs ie SAT, DVD, Cd from the link room but dont know which button to use on my Beo4 to view the PC i n whilst conected to the BV8-40 in the main room.
    I have used Link¬PC, L-PC but to no avail!
    Any help/inofrmation would be highly appreciated.
    Regards
    Jola
  • 06-06-2010 5:21 PM In reply to
    Re: How to watch PC in Link rooms
    Hi Jola!
    At first: How did you connect your PC to BV8-40? If only HDMI, you cannot watch this in your link room! You have to connect the PC also to an analogue input (p.e. VGA).
    Regards
    Räuber
  • 06-07-2010 2:45 AM In reply to
    Hi Rauber,
    Thanks for your response!
    Yes i connected the PC to the BV8-40 using a VGA cable.
    REgards,
    Jola
  • 06-07-2010 4:50 AM In reply to
    Hi Jola,
    I think it should work if you use a VGA cable. I would also connect an audio cable from PC to BV8-40 to check if you can hear audio files from your PC in your link room.
    I think you configured the AV3-socket (VGA) on your BV8-40 as "PC" so you can watch your PC on the BV8-40 by pressing PC. If none of your inputs of your BC 6-23 is configured as "PC" you have only press PC on Beo4 in your link room.
    Hope it works!
    Regards
    Räuber
  • 06-07-2010 5:21 AM In reply to
    Hi Rauber,
    That is exactly what i have done- configured the AV3-socket (VGA) on my BV8-40 as "PC" and can watch PC on the BV8-40 by pressing PC. I also have an audio cable connected and everything works fine on the BV8-40.
    The issue is when i presss "PC"on my Beo4 in my link room when the PC is connected in the main room, nothing happens and i dont have any Pcs connected to the linkrooms - I have a Beocenter6-23 and Beovision6-22 in different rooms and nothing happens on both!
    REgards
    Tony
  • 06-07-2010 6:22 AM In reply to
    Hello Tony,
    in the user guide of the BC 6-23 it is described that the PC-button activates a PC which is connected to the DVI-socket of BC 6-23. Probably therefore "PC" and also "Link PC" does not activate a PC in the main room.
    I would now try to change the AV3-socket of your BV 8-40 from "PC" to p.e. V.AUX. Then you should see the PC-monitor on your BV 8-40 by pressing V.AUX in main room and (hopefully) V.AUX or LINK V.AUX in link room.
    Sorry, I can´t test it by myself because I have no BC 6-23.
    Regards
    Räuber
  • 06-07-2010 9:59 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    L-PC will activate BV8`s PC input on your BC6, but your PC must be connected via video (composite) and audio (L-R) to your videomaster.
    Check it by connecting any video source to the AV3 video input and press L-PC in your BC6 linkroom.
    Stefan
  • 06-07-2010 3:40 PM In reply to
    Thanks Stefan and Rauber,
    I am away from home till the weekend and will surely give this a go and report back if it works!
    Regards
    Jola
