Hello Everyone:
I have the Beosound 9000 system and the remote control has stopped working. I can operate all functions manually but not with remote. I have installed new batteries.
I took the remote to a friend who has the same system and it worked fine on his 9000. This tells me that the remote controller itself is not at fault.
Could it be that the 'eye' that picks up the remote signal on the 9000 needs cleaning? If so, can someone tell me where that 'eye' is?
The remote was working perfectly before our recent move from CA to FL. The item was well packed for the move and did not sustain any damage. Can you think of anything that may have happened in transit, that would stop the remote control from operating?
All help appreciated.
Thank you - Roger
