Latest post 06-03-2010 1:26 PM by stefan. 3 replies.
Page 1 of 1 (4 items)
  • 06-03-2010 12:12 PM
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    Beo4 dont start my BeoVison 10 + BeoSound 5 anymore (my be because of the last SW update ?)
    Hmm... I choose N Radio or N Music via the LIST button press GO but nothing happen :-( Could this be a result from the last SW update ?
  • 06-03-2010 12:24 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: Beo4 dont start my BeoVison 10 + BeoSound 5 anymore (my be because of the last SW update ?)
    Just double check the connectons menu that the devices are still present as when i had a SW update on BV7 some sources dropped off and went back to default.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 06-03-2010 1:00 PM In reply to
    what happens if you press A.Mem of A.Tape?
  • 06-03-2010 1:26 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Same here. Must be a result of the update. Deactivating the BM5 manually by the switch on the back and reactivating the same way helped....
    Now it works as usual.
    Stefan
