The Beomaster 6000 is known to run a bit warmer than other Beomasters
but anything warmer than your hand when playing at low volume is bad.
Note that the amplifier section is at the left side, the power supply at the right side of the large cooling fin.
As Peter suggests, replace and readjust the idle current trimmers and
it would make good sense to replace the electrolytic capacitors while in there. Most of them will be bad or at least marginal by now.
A capacitor kit is available.
