Latest post 06-02-2010 9:27 AM by Olof. 5 replies.
Page 1 of 1 (6 items)
  • 06-02-2010 3:25 AM
    • JL
    • Not Ranked
    • Joined on 05-06-2010
    • Posts 7
    Beovision 10-40 sound
    Hi there!
    I am planning to buy BV10-40 as my first B&O TV. Can you give feedback its sound capability? Does it sound also good when watching music DVDs and BD movies? I have heard BV8 (32 and 40) and its sounds very good. It works very well when only listening mp3s. But can BV10 give as good bass than BV8?
    I am not planning to buy any loudspeakers or subwoofer yet but maybe in future.
    So, is BV10-40 as good as BV8 (price quality) when comparing both sound and picture? Design is deffinitely better (in my opinion).
    Many Thanks!
    JL
  • 06-02-2010 4:47 AM In reply to
    Re: Beovision 10-40 sound
    In my view, no. The sound for the thinness of the set is admirable but is not a patch on the bigger sets. It is very clear - I would certainly consider having a listen for yourself at a dealer - I would try it with and without a BL11 which seems specifically designed to deal with the shortcomings. The picture is excellent though.
  • 06-02-2010 5:54 AM In reply to
    Agree with Peter there. I had a Beovision 8 32", and the sound is more detailed and "open" on the BV10, but lacks depths in bass compared to the BV8.
    Although it still can deliver a more impressive sound than any flat TV on the market.
    I watched "Wolfman" the other night, and there are some "surprise scenes" where my BV10 40"  delivered a very nice "impact sound".
    Scared the crap out of my wife anyway .. Stick out tongue
    I will try out a small Velodyne Sub together with my BV10, until I have saved enough to go for the BL11.
    /C
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 06-02-2010 7:50 AM In reply to
    • JL
    • Not Ranked
    • Posts 7
    Thanks!
    I have to meet my dealer and play my favourite DVD Smile
    Maybe I order my BV10 before South Africa tournament...
    JL
  • 06-02-2010 8:00 AM In reply to
    I have my BV-10 paired with BL8000s, just need to add the BL11 and I'll be a very happy bunny!!
    I wish I had a room suited to 5.1, but it's not laid out that way...
  • 06-02-2010 9:27 AM In reply to
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    So do you think the BL11 would be the right thing to improve the sound of the BV 10 ?
    I saw at my BL 3 that their sound is much more detailed when I connect them with my BL 3... may be I would have the same with BV 10 + BL 11 ?
