Latest post 07-12-2010 3:18 PM by Chrisreunion. 5 replies.
Page 1 of 1 (6 items)
  • 06-02-2010 12:39 AM
    BeoSound 3 aux input
    Hi everyone,
    I know the answer is most probably "no", but I couldn't help ask the question. The BS3 has not aux input, but has SD card slot. Does any company make an audio-jack-to-SD-card adapter? The idea is simple: the adapter takes whatever input is coming through, converts it on-the-fly to a psuedo audio file that the end device then reads. The audio file is continuously added to with new information. Basically, an SD card version of the venerable car cassette adapter.
    If yes, I will acquire a BS3 at once! If no, well... its usefulness would be much diminished.
    Leo
    BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
  • 07-12-2010 10:43 AM In reply to
    Re: BeoSound 3 aux input
    no. Stick out tongue
    I don´t think it is on the market, but I like the idea a lot! Yes -  thumbs up
  • 07-12-2010 11:47 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    I like the idea, too.  however, I would not hold your breath - this would require, among other things, an Analog-to-Digital converter that fits in an SD Card.
    Stan
  • 07-12-2010 1:26 PM In reply to
    Alternative solution .. something like those iPod converters that broadcast an FM signal for a car's radio to tune into ?  Then the BS3 could play such a source ... not as neat as the original idea, but perhaps something that is more easily achieved.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 07-12-2010 1:59 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    elephant:
    I do this from time to time.  The flat top of the BS3 makes a nice shelf for the ipod.  The problem is finding quality open FM airspace in congested urban setting.
  • 07-12-2010 3:18 PM In reply to
    FM transmission is indeed the only solution I'm afraid.
    In my area, where there's not too many stations, I use it from time to time and the sound is far superior to any other FM station you'll be able to receive, because the transmitter is so close to the receiver. Smile
    Reunion Island is greeting you!
