Latest post 06-03-2010 9:56 AM by anodyne1. 7 replies.
Page 1 of 1 (8 items)
  • 06-01-2010 6:52 AM
    Beocenter 9000 1986 urgently searching for a CD laser or replacement CD
    Hi everyone,
    I have a Beocenter 9000 from 1986 (Type 2501, NS 04712987). Just took it to my B & O service man and he revised the whole thing, doors sliding perfectly, cassette and radio excellent, but he said te CD laser is finished and he has no more. I would love to buy either a new laser or a complete CD unit from anyone, anywhere. I love my old B & O stereo and don't want it to sit there and not be used loudly as it was designed.
    Can anyone please help?
    Filed under:
  • 06-01-2010 7:39 AM In reply to
    • AdiS
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Posts 196
    Re: Beocenter 9000 1986 urgently searching for a CD laser or replacement CD
    Hello anodyne1,
    try to contact "Ulf" from the german beoworld - I think it´s possible that he can help you!
    regards, Adrian
  • 06-01-2010 8:06 AM In reply to
    Thank you very much. I'll try to find him.
  • 06-01-2010 8:20 AM In reply to
    I may have one available.
    Neil
  • 06-01-2010 11:16 AM In reply to
    It could also mean some capistors and soldering is the culprit with the lazer being fine!
    Go to Ulf or Dillen in the workshop before buying another lazer.
  • 06-01-2010 11:29 AM In reply to
    If you do I will gladly buy it from you. Thanks.
  • 06-01-2010 11:30 AM In reply to
    Thanks. I have contacted Ulf and he is sending the information for this.
  • 06-03-2010 9:56 AM In reply to
    Hi Neil,
    Did you happen to have the part for the Beocenter 9000? I would like to buy it if you do.
    Many thanks.
