Yes, you can set the default volume starting point. Using your Beo4 remote, adjust the volume on your BL3500 to the starting value you would like to have.
Keep pressing 'LIST' till you see 'A.SETUP'. Press 'Go'. Then press 'LIST' again untill you see 'S.STORE'. Press 'GO' again. That should do it.
Johan
