Latest post 09-29-2011 2:30 AM by kallasr. 3 replies.
Page 1 of 1 (4 items)
  • 05-31-2010 7:55 AM
    beolit 1000 power supply
    hi all i am new here and wondered about the specifics of gettinfg a power supply for my beolit 1000
    Will a new 7.5 watt supply work or do i ned to look for a specific one as a beopower 1000 is pretty rare these days
    chhers
    dave
  • 05-31-2010 8:28 AM In reply to
    Re: beolit 1000 power supply
    Hi Dave, welcome to the forum!
    You will need a 7.5V, at least 1 amp regulated (stabilized) DC power supply. This adds up to at least 7.5W. Make sure the power supply is connected with the negative pole inside the plug, which is the opposite of just about any modern kit! Multipurpose power supplies that have a number of alternative DC plugs will usually have one that fits the Beolit.
    Otherwise there's no specific voodoo in the Beopower, the Beolit 1000 eats DC just like any other similar device.
    -mika
  • 06-04-2010 2:51 PM In reply to
    Now that I'm back at home, here's an example of a known working solution (not that it will help much outside Scandinavia...).
    The correct plug fixed in correct orientation with shrink wrap tube. I would glue the voltage setting at 7.5 as well if this was to be used by "3rd parties"...
    -mika
  • 09-29-2011 2:30 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Just a standard one with 7,5V / 1.000 mA will do - IF you can change the polarity (and the adapter size is right).
    Can be done plugging the adapter vice-versa.
    Just look out for polartiy (+/-) changeable via adapter.
    I bought this one for my Beolit 1000 (packaging is similar):
    On the second pic you see how to adjust the polarity.
    For sure I changed it to 7,5V Smile
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
