Latest post 06-03-2010 11:04 PM by dylan. 1 replies.
Page 1 of 1 (2 items)
  • 05-30-2010 3:59 AM
    connect macbook mini dvi to Beovision 5
    Hi, I have a macbook mini dvi and I want to connect it to a Beovision 2004 non hd for DVD playback and some video streaming. I need to have both image and sound.
    what is the best way to do?
  • 06-03-2010 11:04 PM In reply to
    • dylan
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Perth, Australia
    • Posts 117
    Re: connect macbook mini dvi to Beovision 5
    Hi, I'm no expert (not having either a BV5 or a Macmini Big Smile ) but have been looking at getting a macmini to connect to a soon to arrive BV7. Seems there are issues with the age of the macmini you have - pre 2009 a DVI-VGA adapter seems to work fine (combined with a coaxial for the audio) post 2009 I think you might have to get a mini-displayport to VGA cable, and then a VGA to Composite converter. Have a look at these threads thread thread2 might help.
    Edit - sorry just realised you have a macbook mini not a macmini - but ? above may still be of use
    BS3200 BV7 BV3 BL8000 BG4000 BL4500 PC2 BG5500 MX4002
