Does anyone know how you take the Beo5 in and out of dealer mode to reduce the IR range?
I can't remember for the life of me and it is annoying me to no end as my Beo5 is stuck in it!
BeoVision 7-40 MkV
Go into the service menu, select Dealer Opt, Select Normal Mode instead of Dealer mode and store the change by pressing Back three times.
Thanks Peter, I can get to the setup menu (pressing Go + Standby) but where do you go from there! I remember its something abbout pressing 0+0+1+GO in a sub menu but can't remember which one!
Set up menu then 0 0 Go within 3 seconds.
Hero! Thanks!!
