Latest post 06-01-2010 5:27 PM by Jefbro. 7 replies.
Page 1 of 1 (8 items)
  • 05-28-2010 3:46 PM
    Suitable replacement drivers for P45?
    Hello, I have a lovely pair of P45's which have suffered in the hands of a courier and all the bass drivers have locked up. I have had a look for replacement drivers on the net and dont know which way to turn! Can anyone suggest a suitable brand to go for to complement the original spec?  Thanks   Jeff
  • 05-29-2010 2:19 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Suitable replacement drivers for P45?
    That is very hard indeed as you will also see if you do a search here.
    We've had this sad issue several times but whatever you do, hold on to
    the original woofers, there's a good chance that a repair will be possible
    in the future.
  • 05-29-2010 9:09 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    I have successfully freed a sticking driver on a CX50 but whether the problem is the same on yours is anyones guess. It involved disassembling the driver almost down to its component parts & rebuilding after some quite intensive burnishing of the tube around which the drive coil is wrapped. If the coils have worn/burned out then it would be a pointless task so you need to test them for continuity before even thinking about this. Where are you located?
    Chris.
  • 05-29-2010 10:18 AM In reply to
    • Dillen
    • Posts 5,008
    It's usually the magnet and the center piece that breaks lose. They are glued in place and
    the center piece will be sucked to one side when the glue breaks, squeezing and blocking the coil completely .
  • 05-29-2010 1:29 PM In reply to
    • Medogsfat
    • Posts 4,045
    So it's likely to be a case of trying to realign the centre piece inside the magnet then hmmmm......Hmm
    Chris.
  • 05-29-2010 6:39 PM In reply to
    • Dillen
    • Posts 5,008
    Yes, but the hardest part is putting it all back together without damaging the coil or its former.
    The center piece will inevitably pull to the side unless not allowed to move sideways at all and the magnet
    will smack onto the chassis or pull it towards itself unless the last 5-6cm travel is heavily restricted and the
    chassis fixed in some form of gig.
    I have a nice collection of bad woofers and I've done a lot of tests. Haven't come up with
    a 100% working solution yet though but it could be something including the complete
    removal of the cone, spider and coil.
  • 05-30-2010 10:30 AM In reply to
    • Medogsfat
    • Posts 4,045
    Dillen:
    That's basically what I had to do to free the CX driver. It was really a case of seeing if was possible & probably not worth the effort in that instance but it sounds like worth doing for these older/harder to find units.
    Chris.
  • 06-01-2010 5:27 PM In reply to
    I have tried myself to fix the problem by, as you say disassembling to component parts then trying to reassemble. I did get as far as thinking i'd succeded when i got the cone moving freely along its path when moved by hand but when assembled into the speaker it sounded bad!
    Surely there are thousands of different size speakers out there, one must fit!
    Thanks for your replies.
