Latest post 05-28-2010 8:00 AM by stefan. 1 replies.
Page 1 of 1 (2 items)
  • 05-28-2010 7:45 AM
    BV 7-40 how to operate in link-room
    Hello,
    my BV 7-40 + Technisat HD S2 sat receiver works perfectly fine in the TV-room. I use my BEO 4 with PUC and all functions are fine.
    Now, operation in the link room is not 100%. I can not make the Technisat HD S2 to switch between TV and Radio radio mode. Switching channel is working as expected, so PUC controll must be fine.
    What is not working is to swicht the  Technisat HD S2 fome SAT-TV-mode to  SAT-RADIO-mode.
    To switch in the TV-room I just have to press "MENU" + "5", and it switches. Doing the same in the link room has no effect.
    Any ideas?
    Regards
    Mafanni
  • 05-28-2010 8:00 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BV 7-40 how to operate in link-room
    mafanni:
    Any ideas?
    Regards
    Mafanni
    Just press GO - 5 in your linkroom.
    Stefan
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
