Latest post 05-30-2010 6:02 PM by Steffen. 3 replies.
Page 1 of 1 (4 items)
  • 05-28-2010 1:08 AM
    Beomaster 1900 Decal Lens
    Has anyone reproduced the plastic sheets for the balance, treble and balance controls?
    Is this something that can be scanned and reproduced on a laser printer?
    Have some lenses that are peeling with age.
    Thanks,
    Derek
  • 05-28-2010 1:34 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 1900 Decal Lens
    I experienced with this a couple of years ago and made some in vinyl with inside printing so it won't wear.
    I may have some of the prototypes still around if that will do.
  • 05-29-2010 9:27 PM In reply to
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    Hi Derek
    I have had to make some replacement sheets in the past and they do work very well.  The photo below shows the damaged original from a Beomaster 2400 and a paper print of one that I drew up in AutoCad.  Thereafter, all I had to do was print it out on to  transparency paper and cut it to size.  Everything fitted and works nicely.
    I think that this print will become damaged over time especially if the tone changes and balance changes are frequent.  However, I make very few adjustments to these parameters so everything continues to look good.  In any case, the final print onto the transparency always makes six of these plastic sheets so I do have plenty of spares.
    From memory, the plastic sheets on the BM1900 are a bit simpler with less lines and more solid blocks.
    Have fun
    Geoff
  • 05-30-2010 6:02 PM In reply to
    Actually, they're the same on BM 1900 and 2400. The change came with the "2"-models to the simpler type with less lines.
    Nice work you've done in AutoCad.Yes -  thumbs up
    Steffen
