Hello, I have 3 B&O tv's Beovision 7-40, Beovison 10 and a Beo System 3 (with a 60 inch Pioneer Kuro screen)
On the Beovison 7-40 I have the build in DVB (T-4042) of B&O, works fine, but no HD. On the two other systems I use the Scena 5 sat reciever. These worked okay, but with 3 month both Scena 5's broke done with different issues. The problem is that the Scena 5 is not available any more, replaced by the Scena 5S which is not suppoted by B&O (yet).
In a perfect world I would like the same SAT tuner in all systems.
Question for you guys out there:
Does any one have a suggestion on which SAT system to use?
Does anybody have expirence with the new HD DVB module of B&O?
Regards
Joop Raeven
