Latest post 05-22-2010 8:49 AM by stotty1111. 3 replies.
Page 1 of 1 (4 items)
  • 05-21-2010 11:46 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BG 3500 platter
    hi again
    silly me forgot to ask if there would be any problem using a beocenter 2200 platter instead of the original 3500 one(its badly marked etc)
    Just for asthetic reasons!
    salut
    t
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 05-21-2010 2:49 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: BG 3500 platter
    No problems whatsoever Tony. The only difference is the 2200 platter will appear to sit slightly higher as the edge is slightly different being chamfered.
    Chris.
  • 05-21-2010 3:20 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BG 3500 platter
    thought as much - thanks Chris - Allons y(off we got then!!)
    salut
    t
  • 05-22-2010 8:49 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BG 3500 platter
    Now found and fitted the 2200 platter - brilliant Chris - not prototypically  correct, but it works for me
    Now to give the vinyl a bending and renew acquaitance with it!
    salut
    t
