Latest post 05-22-2010 9:02 AM by stotty1111. 5 replies.
Page 1 of 1 (6 items)
  • 05-21-2010 10:59 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BG 3500
    Hi all
    Trying to reinstate the 7 pin din plug on this deck lead - it had been replaceed with rca plugs
    I think there should be left / right/ data and ground to the plug + a flying earth lead - the manual indicates the blue and white cores are not connected, can some kind soul give me the pin nos on the plug?
    saslut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 05-21-2010 12:06 PM In reply to
    Re: BG 3500
    If you know which colour is which, look at this page. Let us know the colours for future reference!!
  • 05-21-2010 12:56 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BG 3500
    Btilliant as ever Peter
    I normally assume red right white lef tso without a test disc it works for me
    the data cable yellow and the data earth is the black core however I will try it as a fly lead, then as a ground with fly attached
    so based on the attached piece
    i suggest the connections
    pin2 shield (both cores)ground
    pin3 white wrapped core left channel
    pin5 red wrapped core right channel
    pin7 yellow data
    pin6 black data ground (maybe) will verify later!
    heres hoping it all works!!
    salut
    t
  • 05-21-2010 1:18 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: BG 3500
    Tony if it does not work I will open the plug on a BG3300 I have. Ill post a picture of the inside of the plug.
    CraigSmile
  • 05-21-2010 1:41 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BG 3500
    Yet another brilliant kidder!
    I'll let you know!
    salut a la quite hot and suny Finistere
    t
  • 05-22-2010 9:02 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BG 3500
    Ok now sorted it
    the cable has shielded white, shielded red, blue, white, black and yellow cores
    The blue and white are not connected
    the black is just a flying earth wire
    pin 2    earth shields
    pin 3    left channel - I assumed to be left channel and connected the white inner of the shielded cable
    pin 5    right channel - I assumed to be right channel (right - red) and connected the red inner of the other shielded cable
    pin 7    data - yellow
    It does work as have tested on an Ouverture and the BG will activate via the remote play button
    Have also produced a simple extension ie a 7 pin din female to 2 rca's to use with the BS4 which also works however under manual control ie finger on button
    Now to give the vinyl a bending(not literally)
    salut
    t
    NB thanks to all who have offered advice help with this project its taken a long time but eventually I have a achieved a system which works - unfortunately not as I wished - the BS is the master and tv the slave ideally I wanted it the other way round!
