I am about to move house and finally have a full B&O system working as it should rather than bits and bobs just lying around!
What I am planning on having is as follows:-
Living Room
BeoVision 7-40 MK5 (when it hopefully come out in the next month or so!)
BeoLab 7.2
Sky HD, Apple TV and Wii
Kitchen
BeoVision Avant 28" maybe BeoVision 5 if allowed by the Mrs!
Bedroom
BeoVision 6-26 MK1
Whilst I know I will be able to get the Sky, Freeview and Blu-Ray on the link I would like to be able to get the Apple TV as well and here come the problem because you need to have composite going into the TV as well, which you can do and it will then distribute the picture in B&W, which is fine because I only want it for navigating the music but it then changes the settings on the Apple TV from 1080p to 480i and this is not a compromise I want to make!!
I currently use Airport Express and then my iPhone to control but the wireless can be a bit sketchy at times and so I would much rather use the stable ML. Even if it was just to pull the audio through and use the iPhone to control again but when I have tried this before it seems that on say a BeoLab 3500 it will pull through the Audio over the ML if you then go to a TV it says V.Mem on the screen but I get no Audio, so it would seem that if it doesnt see the video then it doesnt even bother sending over the audio either.
Does anyone have any suggestions???
Thanks.
P.S will post photos of install when finished!
