Latest post 05-23-2010 11:10 AM by stotty1111. 21 replies.
Page 1 of 1 (22 items)
  • 05-19-2010 6:31 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BS4 / Aux input question
    Hi all
    Have a BS4 which I am trying to connect a BG3500(with riaa) - I am trying to listen to the input but cannot get it to play thro the system - however, if I call up the bg via a aux and record it to an sd card it works fine  ---  my question is, is this correct, do i have to record all my vinyl to card to listen to it or should I be able to listen to the input directly thro my system - if the former then thats a bit good hey what!
    Observations please!Confused
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 05-19-2010 7:52 AM In reply to
    Re: BS4 / Aux input question
    That is incredibly strange.
    What happens when you connect anything else to AUX e.g. an MP3 player ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 05-19-2010 2:31 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi
    same result - this has got me really p**sed off as I think I've followed the manual to the letter to set it up - what a piece of nonsense this is!!
    salut
    t
  • 05-19-2010 3:02 PM In reply to
    Hi stotty1111,
    What do you use for speakers? Is the BS4 connected to a pair of speakers, or is the connected through your tv with masterlink?
    I was the second place winner on the BeoWorld May 2009 Prize Draw!
    Thanks to BeoWorld for a great site!
  • 05-19-2010 4:16 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    bs is slave to mx7000 with bl4000 speakers on mx
    might try reversing master slave tomorrow if i can find some long pl leads
    salut
    t
  • 05-19-2010 9:20 PM In reply to
    stotty1111:
    salut
    t
    so to better define the problem ... "My MX7000 is not transmitting the AUX command to, or not recognising the AUX traffic from, my BS4"
    Is that correct ?
    But all other BS4 sources are handled correctly: CD, RADIO and A.MEM ?
    Did you set any options: A.OPT and/or V.OPT ?
    And do you precede the CD etc commands with any other BEO4 commands ?
  • 05-20-2010 3:37 AM In reply to
    Hi Tony,
    I bought my BS4 just before new years eve last year and couldn't get any sound from the damn thing!? I tried everything!! But nothing helped. No cd, radio, a.mem or a.aux. New years eve and the days until the B&O shop opened again, seemed like forever. No - thumbs down
    The problem was my BeoVision 8-40. But after a technician came and updated my tv, everything worked!
    But your BS4 work fine with playing cd's, radio and A.MEM? The only problem is with  A.AUX ?
  • 05-20-2010 5:23 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Yep correct(I think!) as I have been using the on board keypad to action record etc
    I have only recently acquired a beo4 so am a virgin so to speak having always used a bl1000 remote tried list-a aux on the beo 4 nothing, used the wheel etc on the bs to get a aux up
    think i need lessons in beo4 useage! - quel pr*tt
    I'll find the beo4 manual and try to reconstruct the thing - meanwhile an idiots guide would be helpful as i am about 150 miles(200km) from my nearest dealer here in France!
    Also, functions by remote work ie tv, v tape, dvd, cd, radio, a tape brings up a mem (sd card) using beo 4 little different by bl1000 as no dvd!
    salut
    t
  • 05-20-2010 2:45 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Ok got it sort of working, can now listen to BG / vinyl thro the system - had to use the ML cofiguration guide as info source the MX and the BS are both programmed to option 1 with the bl4000's off the BS et voila it works but not as previously ie only one source live at a time, with this setup the BG will continue to be herad when the tv is activated etyc
    Anyone out there with any thoughts or do I have to live with it?
    salut
    t
  • 05-20-2010 5:26 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    "A.AUX"+ "GO" on Beo4 corresponds to "SHIFT" + "RADIO" on a BL1000.
    Maybe the "ancient way" works for your setup MX6000 in "V.Opt" "2" <> BeoLink Converter <> BSd4 "A.Opt" "0"
  • 05-21-2010 2:30 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    hi
    been using those command chains with the beo4 and bl1000 and also the v opt 2 a opt 0 - the other aspect being the mx is a later 7000 being from the last year of production so should have the latest software - i'll check later today!
    doooooh this is frustrating!!
    salut
    t
  • 05-21-2010 9:36 AM In reply to
    • Vienna
    • Posts 712
    I configured a similar setup - MX4000IT SW 3.1 (+BLb4 conected) <> BeoLink Converter SW1.3
    <> BSd 4 (updated to current SW = capable of timer recording / 8GB Card) and tested this config
    in both options:
    V.Opt 2 & A.Opt 0 as well as V.Opt 1 & A.Opt 1
    MX4000 and, just for testing, an other MX7000 both "understand" "A.Aux" as well as
    "AV" + "A.Aux" (or "AV" + "Shift" + "Radio") and turn on.
    Remembered, that a similar issue concerning "A.Aux" on BeoLink Aktive & Passive just recently
    has been solved by a new SW 1.6 for these units ...
    Double checked by changing the BeoLink converter to an other one (not older then 6 month)
    - bad news - same result as before.
    The problem seeems to be the BL Converter - obviously beeing not capable forwarding "A.Aux"
    Called the B&O tech support and explained that issue. Tech support told me, that this additional
    "A.Aux" isssue has not been known before and they will notify the SW guys in Struer ...
    Filed under: ,
  • 05-21-2010 10:54 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi
    Thanks for that!
    TV  MX7000 SW 4.7 Type 8702  Serial No  16*******
    Converter    SW 1.3   Type 1611
    Converter    SW  1.0   Type 1614
    Tried both with the tv as master v-2 a-0   no joy all other functions work then both  on v-1 a-1    both work
    Now you have id'd the problem think its time to accept the situation unless the sw upgrade is not long in coming(if ever!)
    Again thanks for your efforts!
    I owe you one!
    salut
    t
  • 05-21-2010 1:26 PM In reply to
    • Vienna
    • Posts 712
    Addendum - Workaround:
    If you are not using one of your AV/SCART inputs (not very likely todays) you can connect your
    turntable/RIAA preamp like a camera (using a SCART <> 3x RCA Phono adaptor) and assign
    "V.Aux" to that input.
    Filed under: ,
  • 05-21-2010 1:48 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Cannot do that as botyh scarts in use , one with a dvd1 and the other with a vcr8000 which has a load of other junk(sky box and french terrestrial box thro an automatic switcher unit) which connect via the rca sockets on the vcr - they are called up as camcorder - messy but it works - the tv has a multi standard tuner which enabled french tv to be viewed however digitalisation occurs here in finistere on June 8th
    Hey ho the best laid plans of mice and men etc!!!!
    salut
    t
  • 05-21-2010 2:27 PM In reply to
    • Vienna
    • Posts 712
    ... go often awry
  • 05-21-2010 3:16 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    certainly do!
    Many thanks for your input - its furthered the challenge!
    salut
    t
  • 05-23-2010 6:18 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Ok guys
    Whilst playing around setting up the system yesterday had another go with the options setup and now with
    Video(tv) programmed to option 2 and
    Audio(bs) programmed to option 2
    Don't know which is the master master but it all works, and the bl4000's are called up whatever is the source, the bg via a-aux or shift / radio also works
    If the tv(or other video pieces) original source ie in operation when an audio source via the bs is called the tv now shuts down and any bs based audio source will kick in/boot up)
    NB the bl4000's are off the bs4 and am using the later converter with the sw 1.3 version!!
    This really is mystifying but hey who cares I'm now a very happy bunny!
    salut a finistere - currently 75'F predicted to be 87'F later
    tony
  • 05-23-2010 8:29 AM In reply to
    • Vienna
    • Posts 712
    Hi Tony,
    of course "A.Opt" "2" + "V.Opt" "2" is a work araund  regarding the "A.Aux" issue of the BeoLink Converter
    The command goes "parallel" and directly to both units and it does not matter anymore the BL-Converter
    is blocking this command.
    BUT !!!
    All other comands like the digits for selecting a track/progam as well as "Step Up" or ""Step Down" are
    doubled (BL-Converter will forward these commands)!
    RESULT:
    You can not step to the next program/track, you'll always go 2 steps up/down
    you press "2" and will get "22"
    WORKAROUND for the Opt 2+2 (command doubling issue):
    use IR Damper 3160078 - (BEO4 Reduced Range) being used in B&O Shops worldwide, but
    you'll have to target at your B&O TV and have to detach the IR damper temorarily to select "A.Aux"
    (... some kind of a hollow victory, IMHO)
    Filed under: ,
  • 05-23-2010 10:08 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    yep you're correct with the cd problem my just discovered earlier this afternoon solution when i could not select any tracks once the cd playing is to press sound then the track number and advance like that - have not tried with the beo 4 as yet bot a similar work round must lie in there somewhere!
    life gets complex don't it!!
    salut
    t
  • 05-23-2010 10:45 AM In reply to
    • Vienna
    • Posts 712
    ... until new SW for BeoLink Converters comes from the north ...  Opt 2+2 and the IR reduction will be the
    least of all evils - giving you access to all sources and "solving" the inherent command doubling issue when
    A.Opt 2 + V.OPT 2 is used for units beeing in the same room!
    Call your B&O dealer and order an IR damper B&O ItemNr 3160078 (BEO4 Reduced Range) - i'ts a one digit
    Euro item and can easily send by post.
    A similar part is available for BL1000 - (but has to be glued on) while the Beo4 version is "plug on/off"
    WORKAROUND:
    (as previously posted)
    buy/use IR Damper 160078 for Beo 4
    you'll have to "target" at your B&O TV
    you'll have to detach the IR damper temporarily to select "A.Aux"
    Filed under: ,
  • 05-23-2010 11:10 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Because of my house layout(open pla) I already have an ir reducer because I have a bc9300 (stand alone) and a bv7.32/bc2 in my lounge area and the bc9300 used to boot up due to spurious ir signals another solution to the proble is to open up the beo4 and coat/blank off part of the ir led(tip from a BnO dealer in Shrewsbury UK- - used a model paint opaquifier to good advantage
    will continue to post as more info to hand!
    salut
    t
