Latest post 05-19-2010 6:33 AM by scanorama99. 2 replies.
Page 1 of 1 (3 items)
  • 05-19-2010 6:13 AM
    Beovision 6 panel needed (mine have burnt-in spots)
    This is a long shot but if anyone perhaps have like a broken beovision 6-26" and maybe with some damages on but with the screen (lcd internal panel) intact and can spare the panel please contact me.
    The repair cost of replacing the panel with a new one is quite a bit above my budget and since this one is really heavily used (demo item) it is quite adequate with a normally used piece for the repair.
    Thanks in advance
  • 05-19-2010 6:19 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beovision 6 panel needed (mine have burnt-in spots)
    Maybe - if somebody on this forum knows the exact Model etc. - you can just get a Samsung (?) TV on which the Beovision is based. These should be prettay easy to get for a lower price.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 05-19-2010 6:33 AM In reply to
    It is the first beovision-6 26" with fabric on the speaker cover.
    The production number (might me serial number) is 18118258
    Thanks by the way for the samsung suggestion. That seems like a resonable option if I only find out what the right panel is.
