Could be broken connection within the plug. Can you dismantle it and check the solders?
Other than communication, is the sound level from the deck OK? You could be plugged into AUX or TAPE2 instead of PHONO!
Regards Graham
joeyboygolf: Could be broken connection within the plug. Can you dismantle it and check the solders?Other than communication, is the sound level from the deck OK? You could be plugged into AUX or TAPE2 instead of PHONO!
Beat me to it Graham.
If it worked before then this is the most likely explaination. It's a few years since I sold my Beocenter and if memory serves me correctly the phono input socket access is a bit tight on these and tend to put stress on the plug.
Chris.
Chris you are correct about access to the Phono connection. On my BC9000 I never used to close the small flap that covers the connections. If you did it pushed the connections to the side slightly.
Craig
Ah - maybe there's some life left in me yet then Craig?
