Latest post 05-17-2010 12:25 PM by Stefan Zueger. 3 replies.
Page 1 of 1 (4 items)
  • 05-17-2010 11:30 AM
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    How can i get the covers into iTunes if i user .wav format ?
    Some covers are missing and the software CoverScout dont works with .wav files ? Any ideas ?
  • 05-17-2010 12:07 PM In reply to
    Re: How can i get the covers into iTunes if i user .wav format ?
    Olof, given you mention Coverscout and this is a Mac forum, I assume you are using iTunes for Mac OSX?
    If so, doesn't iTunes convert the WAV-formatted files to AAC or MP3?
    Anyway, if Coverscout fails to find Cover information, you may try to install the following Apple script:
    Search CD Universe for Album v1.0
    Find Album Artwork with Google v2.5
    Search SlothRadio for Artwork v1.1
    They all work the same: You mark one of the tracks without covers, execute the script, the script will send a search string to the respective service, bring up the cover in Safari and you manually copy the picture to your tracks.
    Kind regards, Stefan
  • 05-17-2010 12:16 PM In reply to
    • Olof
    • Posts 141
    Hi Stefan,
    the script works, but iTunes doesnt allow me to copy the cover into the file ? :-(
     Kind regards
    Jan
  • 05-17-2010 12:25 PM In reply to
    Hello Jan
    I googled a little bit - it seems WAV does not support artwork:
    http://support.apple.com/kb/TA27633?viewlocale=en_US
    So you will have to decide if you listen to these tracks without artwork or if you convert the file to e.g. AAC and add the artwork then.
    Kind regards
    Stefan
