Latest post 05-18-2010 4:02 AM by ralfja. 4 replies.
Page 1 of 1 (5 items)
  • 05-17-2010 10:46 AM
    New Iphone app for Bang & Olufsen
    More info: http://web.me.com/philrobin/LinkPlayer/Linkplayer.html
    Has anyone tried it?
  • 05-17-2010 11:38 AM In reply to
    Re: New Iphone app for Bang & Olufsen
    This was made available in the Apple store last month and is a very nice App. However, it is only useable with the Masterlink Gateway, but you can use the demo mode to see how it is intended to work.
    Regards Keith....
  • 05-17-2010 11:42 AM In reply to
    Keith, you're talking about the original B&O iPhone App.
    This one is different and works with Beoport and Linkplayer on a Mac.
    For the moment it only controls the sources as accessed on the Mac, it is not yet a remote control for all the B&O in your house.
    There is a whole thread in the Mac forum.
  • 05-17-2010 12:07 PM In reply to
    Thanks for that.. I missed that one, not being a MAC user.
    Regards Keith....
  • 05-18-2010 4:02 AM In reply to
    If you need "a remote control for all the B&O in your house", use this one:
    http://forum.beoworld.org/forums/t/33557.aspx
    It doesn't have the B&O codes in its database which means it needs to learn all the codes first (by pointing the Beo4 to it and send button by button). Once you created the buttons and learned the codes it works perfectly.
    Ralf
