Hi all
I've been enjoying my BL5 for a year or so now, but have recently had a problem where the synch cable not working.
As I am using the BL5s with a non-B&O system I use the sync cable to keep each speaker's volume setting in check as well as power on/off functions (since the remote doesn't speak to each speaker reliably 100%).
This problem began intermittently over the last month.
Previously disconnecting the sync cable from both speakers and then re-connecting it resolved the problem but not this time.
It could be an unreliable sync cable? If so, what type of cable do I need to replace it with (if I don't want to bother with B&O) ?
Any other suggestions or hints greatly appreciated.
Adrian
