Latest post 05-14-2010 10:28 PM by elephant. 3 replies.
Page 1 of 1 (4 items)
  • 05-14-2010 6:05 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Connection Help Please
    Hello All
    So i have the following systems to conenct together:
    Beovision 7 (masterlink)
    Beocenter 9300 (Datalink??)
    So i know i need to connect the Masterlink to a 1611 convertor box.
    Do i need to connect both the DATA AUX lead and a powerlink lead to the other side of the convertor box or just the AUX lead??
    I want to be able to get sound from the beocenter on the tv and sound from the tv on the beocenter
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 05-14-2010 11:50 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Connection Help Please
    Hi all
    so far i have connected the tv and 9300 via masterlink and the convertor firstly my tv would not see radio and cd.
    i made sure my tv was in option 2 mode again and it started to work
    i have noticed that if i press cd the room where the bv7 is that the bc9300 fires up th cd player and also the passive speakers that are connected to it, is there a way to change this so it does not make the bc9300 room come on also.
    currently i cannot hear and of my video devices in over the masterlink but they are all connected via HDMI only so i need to look at connecting the ATV with some phono leads to test this.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-14-2010 1:00 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    ok next update
    i have connect ATV with Phono and i have ATV sound in my link room.
    all this is new to me.
    So my question is if i update the tv with the new software will i be able to access the sound from external devices that are only connected via HDMI???
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-14-2010 10:28 PM In reply to
    Seanie:
    I think that's the way it is with passive
    I believe the 9300 has an MCL - what if you make the 9300's room a link room ?
    And I suspect you will need the newly announced software upgrade (see that thread) to get the other HDMI sound sources through your BV ... check the thread to see if your BV is of the right type and generation
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
