        1st March February 2012
	    Latest post 05-14-2010 3:42 PM by  Daniel. 8 replies.
								        05-14-2010 5:54 AM
									        Leslie
								                - Joined on 05-07-2009
								                - Netherlands
								                - Posts 2,201
										    Quick question,
For which TV set is the stand made for?
Mounting holes can be set in two positions 71cm and 79 cm.
It doesn't fit on a MX6000, that's what I know.
Thanks guys!
									    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
									        Craig
								                - Joined on 03-29-2007
								                - Costa Del St Evenage
								                - Posts 4,855
										    Possibly for an LX series then. They both use the same stands but use different top plates.
Craig
									    For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
									        Peter
								                - Joined on 12-28-2009
								                - Sweden
								                - Posts 134
yes, it looks like the one I have on my LS5500 so it should be the same like the LX i suppose.. the ones with speakers on the sides
/Peter
									        Daniel
								                - Joined on 04-17-2007
								                - Svinarp, Sweden
								                - Posts 1,284
										    It's similar but not identical to the stand for my LX 5500. The unfolded parts are on my stand opposite each others. On yours it looks like one of them ends before the other. I'll attach a photo of mine.
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    Thanks guys!
Again, what a wonderfull place to be here
According to the dims (products) of the LX 5000 & 6000 this would be 78 & 86cm width (difference 8cm), so that would match my dims I measured!
									        Beowulf
								                - Joined on 04-16-2007
								                - Derbyshire
								                - Posts 143
										    You are welcome, I will take a closer look at My LX6000 in the bedroom and get back to you tomorrow.
Kind regards
Dave
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    Thanks Dave, very kind of you!
									        Daniel
								                - Svinarp, Sweden
								                - Posts 1,284
										      Leslie:
Thanks guys!
 I believe LX5500 and LX6000 has the same width, both have a 28'' screen.
        Page 1 of 1 (9 items)
