1st March February 2012
Latest post 05-13-2010 3:23 AM by avus17. 7 replies.
05-13-2010 2:10 AM
avus17
- Joined on 04-16-2007
- Posts 336
BeoSound drivers (Software) - need help
I have new PC with Windows 7. Now I can not upload BeoSound 2 software (drivers) as at it seems these are not compatible with Windows 7. Can somebody tell me a solution for that. Windows XP is obsolete now, and new Windows versions are not supporting BeoSound 2 software. Does this mean now I have to throw away my BeoSound 2?
But I could upload BeoPlayer without a problem.
I have also tried to ipload mp3 files via a card reader directly to SD card ant put in a BeoSound2 then but it is not playing.
Thank you for any help.
alenvprekrsku
- Joined on 05-25-2009
- Slovenia, Ljubljana
- Posts 426
Re: BeoSound drivers (Software) - need help
@avus17,
živ si? Nič se ne oglasiš! Bom te poklical še enkrat pozneje, ko izvem pri Rabiču za rešitev.
Other guys,
I'm sorry because I use a foreign language.
Edit: For Admin!
Is there a possibility to introduce the Balkan BeoWorld in BeoWorld around the world?
BS 1, BeoCom 2, 2x LC 2, Form 2, BS 2, BS 3, 2x Beo 4, BS 5, BM 5, BL 5,Beo 6, BS 6, 2x A8, BV 8-40, BL 8000, 3x A9 Keyring, Serenata, BeoTime, BeoTalk 400
Peter
- Joined on 02-12-2007
- Posts 9,572
Can you not set Windows to act as XP - I thought there was a facility to do this for just such scenarios. Obviously the problem is with B&O as they should update the software ......
On the Balkan forum thought, we did actually have more languages but stopped some simply because the traffic was so small and it was inpossible to moderate these forums - by that I mean housekeeping and clearing duplicate posts etc. I personally have no problems with posts like yours above to specific people. A translation to reach a wider audience could be an answer.
avus17
- Posts 336
Živ sem Alen, vendar ne morem govoriti v službi po telefonu, kar veš, zato ti tudi ne bom dvignil! Obstaja tudi mail.Oglasi se tam in ti napišem več. Čestitam za BL5
Sicer sem zadevo rešil in ne rabiš spraševat Rabiča, BeoSound2 se nastavi v i-Tunes mode in dela z WindowsExplorerjem, MediaPlayerjem ali i-Tunes-i
LP
avus17
- Posts 336
I have the answer already:
If you have Vista/Windows7, set BeoSound 2 in ''Mass Storage mode''
Once BeSound 2 is in iTunes mode you can use Windows Explorer, Windows MediaPlayer or iTunes to transfer music to BeoSound 2
alenvprekrsku
- Posts 426
Translate of my first post: You are alive? Not respond to my calls! I will call you again later when I find the solution of the tehnician.
Br. Alen
avus17
- Posts 336
oglasi se na mail, v službi ne morem govoriti
alenvprekrsku
- Posts 426
avus17:
OK!
Page 1 of 1 (8 items)
