Latest post 05-13-2010 9:30 PM by nivlekttrub. 2 replies.
Page 1 of 1 (3 items)
  • 05-10-2010 8:38 PM
    Need Help Adjusting Beogram 4004 Tone Arm
    My tone arm on my Beogram 4004 is no longer parallel to the detector arm when the system is at rest, it sits too high. I tried adjusting the settings as shown in the service manual but no luck. Can any one help?
    nivlek
  • 05-11-2010 1:13 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Need Help Adjusting Beogram 4004 Tone Arm
    Welcome to Beoworld !
    Is the tonearm too high or the sensor arm too low ?
  • 05-13-2010 9:30 PM In reply to
    Hi Martin
    Thanks for your quick response
    The sensor arm is at the correct height, and the unit seems to play well. I adjusted the counter weight. The arm balances parallel to the sensor arm.
    I set the tracking to 1.2. It is only when the arm is cued up or off when it seems to be resting at an an upward angle. I've got the service manual but don't want to monkey around too much.
    Kelvin
