Latest post 05-20-2010 3:54 PM by tournedos. 6 replies.
Page 1 of 1 (7 items)
  • 05-10-2010 3:56 PM
    Problem with my Beogram 7000 CD
    I recently bought a used but very good looking Beogram 7000 to step by step build up a vintage Beosystem 7000.
    As I said, it looks perfect, no scratches no dust etc. but if I insert a CD it shows "Track" on the left side, starts and stops after 15 - 20 seconds.
    If I start it without a CD I hear the motor "roaring" up 2 times when it tries to spin a CD that isn't there.
    Is it because the Beomaster 7000 is missing and the system realizes that??
    Best regards
    Stephan
  • 05-10-2010 4:11 PM In reply to
    Re: Problem with my Beogram 7000 CD
    No, it means that the laser is not focusing. Take it to a dealer and he will tell you it needs a new laser. However it probably needs the capacitor on the servo board replacing as mentioned in other threads.
  • 05-20-2010 2:52 PM In reply to
    Hmm, got the Beomaster 7000 now and I could test it... Some CDs work perfect and play from beginning to the end without a problem, others simply don't show the tracks and the CD goes into sleep mode.
    Any ideas? Is it really the laser?
    Best regards
    Stephan
  • 05-20-2010 3:16 PM In reply to
    I am sure the laser is fine but the caopacitor will be going!
  • 05-20-2010 3:20 PM In reply to
    Me too. Search for "C2103" and you'll find the info. If you aren't able to repair it yourself (do NOT offer it to a dealer!), I know at least two German members (Ulf and Die_Bogener) who can most probably fix it for you.
    -mika
  • 05-20-2010 3:30 PM In reply to
    Guys thanks for the *very* quick replies (you're online all the time so it seems) ...
    I've found that very technical thread and I simply didn't understand anything, I think I will contact Ulf for a fix...
    By the way, the sound of the CDs that work is really mind-blowing!
    Love it!
    Many thanks
    Stephan
  • 05-20-2010 3:54 PM In reply to
    We aim to please! Laughing
    As the CD still mostly works, I'm sure it can be fixed. Best of luck collecting the rest of the pieces, it really is a splendid system!
    -mika
