Latest post 05-11-2010 11:27 AM by Stan. 4 replies.
Page 1 of 1 (5 items)
  • 05-10-2010 11:33 AM
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    BeoSound 5 NetRadio, how does it works ?
    Does the internetradio always need the server from B&O; or is it also possible to programm own radio channels into the BS 5 (BeoMaster) ?
  • 05-10-2010 1:44 PM In reply to
    Re: BeoSound 5 NetRadio, how does it works ?
    No, sorry.
    B&O has their own database. The address of this is mentioned in the windows register.
    To get the N-Radio working, you always need a pc/mac where beoplayer/port is installed and registered.
    Otherwise the BM5 will not get the data about the radio channels.
    My experience is that every 2 weeks the list will be updated.
  • 05-10-2010 2:55 PM In reply to
    • Olof
    • Posts 141
    But thr PC/Mac must not be connected all the time with BS5 if I want to listen to netradio ?
  • 05-10-2010 3:23 PM In reply to
    No, sure not.
    You only have to do this once.
    If you don't, the BM1 or 5, gives you the message: "Not Registered".
    So, after installing Beoplayer/port and registering you leave the PC/Mac on. Then start NRadio.
    Then you'll see the system (BM) updating on regular base.
    Of course, not mentioned, but required, a working network.
  • 05-11-2010 11:27 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Olof:
    Once you've registered the BS5 using BeoPlayer/BeoConnect (happens automatically during install), no computer is required to use N.radio.  You cannot add your own stations.  I'm told you can write B&O, and they will add it.  Although I haven't tried this myself, I do believe this because there are thousands of stations on the BS5.
    Stan
