Latest post 05-12-2010 9:40 AM by Dillen. 10 replies.
Page 1 of 1 (11 items)
  • 05-10-2010 8:24 AM
    • RENATO
    • Not Ranked
    • Joined on 05-10-2010
    • ITALY
    • Posts 7
    BEOMASTER 6500 ---NO RED LIGHT WHEN PLUGGED IN-----HHHHHEEEELLLLPPPPPP PLEASE
    HI EVERIBODY,
    FIRST I APOLOGIZE IF MY ENGLISH IS NOT GOOD SOMETIMES,....I'M FROM ITALY!!! I  HOPE IN YOUR INTERPRETATION !!!D
    I WOULD KINDLY REQUEST ANYONE COULD HELP ME TO MAKE MY NEWLY ARRIVED BEOMASTER 6500 POWER UP.
    IT ARRIVED THIS MORNING BOUGHT ON EBAYUK ,FROM northernrock99 ,AND IT SHOWS WHAT FOLLOWS:
    WHEN YOU PLUG IT IN ,YOU HEAR ITS CARATERISTIC LITTLE CLICK , BUT NOT MORE! :(
    .....I LINKED SPEAKERS,ANTENNA, AND THEN PLUGGED INTO ELECTRICITY......
    I PRAY ANYONE KNOWS ABOUT THAT TO HELP ME,PLEASE.
    I SENT AN E-MAIL TO THE SELLER FEW MINUTES AGO....ASKING IF A CODE IS REQUIRED,  ..AS I DON'T KNOW THIS MODEL....REALLY HOPE SOMEONE'S HELP!!
    THANKING IN ADVANCE I WISH YOU A PLEASENT AFTERNOON
    RENATO.
    Filed under:
  • 05-10-2010 8:31 AM In reply to
    • RENATO
    • Not Ranked
    • ITALY
    • Posts 7
    Re: BEOMASTER 6500 ---NO RED LIGHT WHEN PLUGGED IN-----HHHHHEEEELLLLPPPPPP PLEASE
    I WANTED TO ADD THAT ON THE E-BAY PITCURE THE SYSTEM WAS ON, AND ARRIVED HERE SAFE, PERFECTLY PACKAGED, SO IT IS NOT POSSIBLE THAT WAS BROKEN DURNG TRANSIT.
  • 05-10-2010 8:39 AM In reply to
    If there is no red light, you are not getting power. The problem could be as simple as a loose wire in the power cable plug. That would be the first thing to look at. After that, check the fuses, though if a fuse has blown, there will be a reason.
  • 05-10-2010 8:28 PM In reply to
    He said he hears a click (relais) so it must have power.
    I had exactly the same issue when I bought mine (Beomaster 6500) some time ago from the UK. Seller offered me to send it back and got a full refund. Funny thing is that it was fully functional when he got it back????
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 05-11-2010 2:40 AM In reply to
    Lots of equipment from this era has contact problems or bad solderings to begin with, which may create all kinds of issues when the friendly shipment guys throw them around and play football with them shake the packages a little bit.
    It's impossible to say what the actual problem is without investigating further, but it does need service now, and I'm afraid it will be more involved than opening the lid and saying hello to the insides Sad If you are not able to repair these things yourself, the easiest solution might be to do as Leslie did and return it...
    -mika
  • 05-11-2010 2:05 PM In reply to
    • RENATO
    • Not Ranked
    • ITALY
    • Posts 7
    the fact is that seller does not accept return, that I had to arrange courier by myself,paying 30£.
    aniway ,after the controversy will be solved , I'll ask B&o how much does it cost to repair it.
    I hope to get a refund ,so that I can make it work again.....also if I think that 80£ will not be enough!!!
  • 05-11-2010 2:07 PM In reply to
    • RENATO
    • Not Ranked
    • ITALY
    • Posts 7
    p.s......as I said the package arrived perfect ,clean, with no sign of damage at all
  • 05-11-2010 2:16 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Check the fuse on the powersupply and amplifier board. It sits well hidden
    in a corner close to the mains transformer. Not easily accessed.
  • 05-11-2010 4:48 PM In reply to
    • RENATO
    • Not Ranked
    • ITALY
    • Posts 7
    THANKS A LOT FOR YOUR ADVISE MARTIN, I'LL DO IT!!! .....AND MAKE YOU KNOW WHAT HAPPENS THESE DAYS!!
    !:D
  • 05-12-2010 8:34 AM In reply to
    • RENATO
    • Not Ranked
    • ITALY
    • Posts 7
    hi martin,
    I did it !
    I could see two fuses , both good yet!
    any other ,please?
    thanks in advance
    p.s. it does give a click,but the front panel is off!
  • 05-12-2010 9:40 AM In reply to
    • Dillen
    • Posts 5,008
    You can't always see on a fuse if it's good. You will have to measure a bit.
    Next step will be to check the large filter capacitor next to the fuse on the board.
