Hi @ all
I do have a funny Problem with the picture in my linked room. I  acces my tape which is in a another room hooked up to a BV5 and I access it at my BV7 downstairs. It used to work (I took out my STB recently that is the only change I made and I am reprogramming my Beo5 now and by testing I realised it).
Now I have a snowy picture but when I unplug the main tv signal cable going into the BV5 the picture downstairs at th BV 7 snet by the video tape is fine but then I cannot watch television in either rooms. The tv signal downstairs is okay when in normal setup. Only if I try to access the tv signal from the BV5 upstairs that is snowy as well. I have looked at all the cables and everything seems to be okay. I do not have any explanation for this. Maybe somebody has an idea what the problem is?
