Latest post 05-09-2010 6:43 PM by PhilLondon. 5 replies.
Page 1 of 1 (6 items)
  • 05-09-2010 3:22 PM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    BV7 - Beocenter 9300 question
    Hello All
    If i connect a BV7MK3 with a beocenter 9300 with a beolink convertor 1611 will i be able to access the Vmem source on the tv from the beocenter as Vmem is my applye tv in my main room.
    Is this possible
    can i also select vmem on the 9300 or will i have to use the beo4 to select this each time. am i correct in thinking i will have to use the remote to the convertor knows which sourse to activate??
    some help please as this will be my first older system to newer system connection.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 05-09-2010 4:56 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: BV7 - Beocenter 9300 question
    If I understand you correctly then, the BC9300 and BV7 are in different rooms? You will only be able to select V.Mem with the Beo4. There is no V.Mem button on the 9300.
    CraigSmile
  • 05-09-2010 5:03 PM In reply to
    V.MEM is the same as V.TAPE.
    I assume the Beocenter and the 9300 are in different rooms. If that's the case set the both Beocenter and the Beovision to Option 2.
    When in the Beocenter 9300 room, simply call V.MEM from your Beo4, or V.Tape from a Beolink remote, and all the commands will be transferred. It is however difficult to control an Apple TV without a screen.
    On the Beocenter 9300 itself, there is no Key for V.TAPE. But I think you can use the AUX button, followed by a number.
    I think AUX then 1 (pressed within 1 second) is for TV.
    AUX then 2 is for sat...
  • 05-09-2010 5:22 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Hello
    thanks for both of your replies
    yeah the BC9300 will be in a different room to the BV7, the bc9300 will be connected to some passive speakers in my kitchen.
    i will have to use the beo4 to select Vmem and and control the volume,  i use apple remote app to control my apple tv around the house so the lack of screen will not be a problem.
    can vmem be selected using the AUX......1,2,3,4,5 method do you know??
    also if i have the most up to date software on the TV will it allow me to watch DTV (hdmi) in the lounge and access the Apple tv sound in the kitchen if it is only connected via HDMI without the delay i read about or will i have to connect with Phono to get the sound via masterlink??
    Thanks again
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-09-2010 5:39 PM In reply to
    • Craig
    • Posts 4,855
    Seanie:
    Not sure it works like that on a 9300. Just tried pressing AUX on one I have at the moment. Just the AUX light comes on. When I had a 9000 connected to my BV3-32. If you pressed AUX, AUX would light up but so would the numbers 1,2,3,4 & 8. 1-4 would send the sound from 4 different sources connected to TV through the 9000's speakers. For example.
    AUX, 1 - RF connection
    AUX, 2 - STB
    AUX, 3 - VCR
    AUX, 4 - DVD
    AUX, 8 - sent the input from the mic connection straight to the speakers.
    CraigSmile
  • 05-09-2010 6:43 PM In reply to
    Seanie:
    You will...
