1st March February 2012
Latest post 05-09-2010 12:10 PM by MoglesMac. 10 replies.
05-08-2010 9:00 AM
andreabang
- Joined on 05-21-2009
- Italy
- Posts 98
how do i connect beocenter 9300 on beosystem 3?
once connected,When i will press "CD" on beo4 will it automatically recognize the beocenter?
thx
andrea
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
Re: how do i connect beocenter 9300 on beosystem 3?
Hi Andrea,
you will need a 'new' BeoLink Converter, a MasterLink cable, a fully wired PowerLink cable, and an Aux/Datalink cable to hook those 2 together. You will want to set the 9300 to Audio Option 0 and the BS-3 to Video Option 2. Everything should be fine from there.
Good luck!
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
andreabang: When i will press "CD" on beo4 will it automatically recognize the beocenter?
Yes!
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
Hello
Funny enough i come one here to ask the same exact question but connecting a Beocenter 9300 to a BV7.
so what is the difference with the beolink convertor 1611 and 1614.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
stefan
- 200 miles from Struer
- Posts 1,733
If I remember correctly 1614 is a earlier version - you will need 1611. There is also a 1610 for AV9000 and a 1615, called Beolink Video.
Stefan
PhilLondon
- London
- Posts 2,545
Note that you lose 2 way control, if you have a Beolink 5000 or 7000.
stefan
- Posts 1,733
Sorry, BC9300 is no two way system.
Stefan
Seanie_230
- Posts 962
Hello
So i need to get the beolink convertor 1611 for use with the 9300. I have never had a two way system so i am not going to miss anything.
MoglesMac
- Joined on 04-25-2007
- Sweden
- Posts 109
@PhilLondon
Will I also loose 2 way control via MCL? (I have a BeoSystem 7000 wich i plan to link via Beolink 1611 to a BV8, the Beosystem have also a MCL to a bedroom). Dont mind to loose 2 way in mainroom but wonder if 2 way will still work in bedroom (linkroom via MCL)?
Thanx in advance
Jesper
Sweden
PhilLondon
- London
- Posts 2,545
You do not loose 2 way from MCL Link rooms.
You only loose 2 way in the main room if you connect all speakers to the TV and set the TV to option 2. But this is still the recommended setup.
p.
MoglesMac
- Sweden
- Posts 109
Oh, ok hmm think i really want my Beolab Penta 3 connected to BS7000 since they will be 98% of the time only be used for music, and maybe now and then used as "movie-speakers".
Again thanks for the information :D
Jesper
Sweden
Page 1 of 1 (11 items)
