Latest post 05-08-2010 7:37 PM by BoxOPwn. 6 replies.
Page 1 of 1 (7 items)
  • 05-07-2010 6:59 PM
    • BoxOPwn
    • Not Ranked
    • Joined on 05-07-2010
    • New England
    • Posts 21
    Beocenter 3500 Output
    Is it possible to get un-amplified output from the beocenter 3500, such as an output directly from the turntable?
  • 05-07-2010 8:52 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beocenter 3500 Output
    Welcome to Beoworld.
    What exactly do you want to do which requires this?
    Chris.
  • 05-07-2010 9:08 PM In reply to
    • BoxOPwn
    • Not Ranked
    • New England
    • Posts 21
    I would like to have the option to use the turntable with a different amplifier, when listening with headphones.
  • 05-08-2010 6:15 AM In reply to
    • Medogsfat
    • Posts 4,045
    Why not just plug your headphones into the BC3500? The amp is a very good one on this unit - it is basically a Beomaster 3000 which is one of the better ones made by B&O.
    There isn't an easy/direct way of using the turntable signal with another amp.
    Chris.
  • 05-08-2010 2:14 PM In reply to
    This is one of the few beocentres you can do this.
    The Beocentre 3500 was a Beomaster 3000 with a turntable cobbled on, quite effectively as it turns out.
    This shows up because the Beocentre still has the external turntable connections that belonged to the original Bemaster 3000.
    On the back of the Beocentre 3500 you will see two connections for turntables, Q1 and Q2, for differant signal levels, you will see that one is occupied by a DIN plug, (I think its Q1) and this is a jump lead to make the bridge between the original Beomaster 3000 design and the 3500.
    The front panel has switches for Phono 1 and Phono 2, where Phono 1 goes to teh Q1 connector and Phono 2 goes to the Q2 connector.
    All you do, is to plug the Q1 jump lead into your extra amplifier, easy as that, and of course you would need to set your Beocentre to run Phono 1 to get the turntable to power up, it wold probably be a good idea to ensure both sets of speakers are off
  • 05-08-2010 3:16 PM In reply to
    • Medogsfat
    • Posts 4,045
    And this is why Casdave is a technical advisor on Beoworld.Big Smile
    I didn't know about the Q1 & Q2 connections.
    Chris.
  • 05-08-2010 7:37 PM In reply to
    • BoxOPwn
    • Not Ranked
    • New England
    • Posts 21
    Thanks, your response has been very helpful.
