Hi
I am the happy owner of a pair of BL 4000s, but I would like to go for an upgrate soundwise. The thing is just that on my student budget, there is no room for BL 5s, so I see two options:
Either selling the BL 4000s and buying a pair of BL 3s or
Adding a BL 2 to the BL 4000s.
Which one of the two would give the best result do you think?
Thanks,
Thomas
I am a big fan of 4000s. I would say keep them and get the Beolab 2, or maybe the new Beolab 11.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Hi, depending on your room size, you may not necessarily need a BeoLab 2, but a BeoLab 11 might be enough to give your 4000s a new life!
Reunion Island is greeting you!
If you mainly miss Bass you should go for one of the Subs. I preferred the BL3 over the BL4000 mainly because of the clearer treble. In a direct comparison it is like "opening the window" when you move from BL4000 to BL3 - clearer treble due to Acustic lens. Bass is like the same. BL4000 has a "warmer" sound.
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
Thank you very much for your quick replies and good insight.
The room is only 4 x 4 meters, so you might be right about going for the BL11 instead.I think I'll go for one of the subs, but will go to my local dealer and have a listen to the different set-ups. I was actually considering buying the BL2 second-hand which should be about the same price as a new BL11... A listen should clear things up...
