Latest post 05-03-2010 5:52 PM by Craig. 2 replies.
Page 1 of 1 (3 items)
  • 05-03-2010 11:27 AM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beocenter 9300 - No sound on speaker 2
    Just connected up a Beocenter 9300 I have purchased. It has a problem where there is no sound from the Speaker 2 connections. What I have found is that if I connect the speakers to the Spekaer 2 connections. Then jiggle the plug for the left speaker the right will come on but sounds a bit muffled. Nothing seems to come from the left side, no matter what I do. Speaker 1 connections seem to work perfectly. As does the muting relay.
    CraigSmile
  • 05-03-2010 11:47 AM In reply to
    Re: Beocenter 9300 - No sound on speaker 2
    The spkr 2 connectors are connected pretty much directly to the output amp while spkr 1 take the longer route through the muting relay... can't be sure without the 9300 service manual, but I can't believe that this could be anything else than a problem in the connectors themselves, their solderings, or the wiring that leads up to them. The solderings might have cracked if somebody yanked on the no.2 cables in the past.
    -mika
  • 05-03-2010 5:52 PM In reply to
    • Craig
    • Posts 4,855
    tournedos:
    Indeed they had Mika, you were spot on. It had also damaged the tracks on the PCB. With a bit of patience and a soldering iron, I have repaired the tracks and it is all working perfectly. Quite happy as this is the first time I have worked inside a Beocenter 9XXX/8XXX.
    CraigSmile
