Latest post 05-10-2010 1:14 PM by DirtyDiana. 7 replies.
Page 1 of 1 (8 items)
  • 05-03-2010 8:43 AM
    BL9 Impressions):
    Hello all,
    I recently sold off my Audiophile gear consisting of Mark Levinson,Pass pre/power,Revel F52,Kimber cables to get into B&O simplicity and practicality and still have great performance aswell.
    I got a bit bored of swapping expensive cables around and I never really ended up with an ideal sound-there was always a weekness somewhere in the high or low reproduction.So moving away from the conventional route I became interested in ALT and liked the idea of not having such a presice sweetspot, less clutter and extra ££$ in the bank...
    I had almost done a deal on used BL5 but it fell through at the last minuite so a beauty pair of BL9 came up and I snapped them up asap along with a BS9000.I was always in two minds about the BL5 since the listening room is 8mX4m and I wanted them away from the back walls and 7ft apart which always favoured the BL9's footprint so it was no dissapointment to end up with the Penguins.
    After marvelling at the sheer build quality of the speakers and the beauty of the player we connected everything up and positioned the speakers with a slight toe in (which I later discovered to be a mistake).
    I began playing some farmiliar CDs and the first thing that struck me was that the sound stage seemed to be lower down than before but then it occurred to me that it was just an illusion of not having a huge 5ft tall speaker and 5 shelf rack in front of me which was always a focal point when listening.The next thing was the difference in midrange character and at first thought it was dissapointing until realising that it is just not blasted at you like a conventional speaker with a slight toe in would do which is a matter of taste.I then listened to some Classical and this is where the suprise was-a track that seemed fairly flat and undynamic before was absolutely stunning in the way violins were delivered with such dynamic power and accuracy,it left me pretty shocked at discovering such a difference in dynamics and moving onto some Pavarotti again I never heard the music presented in such a realistic enjoyable way before its like the B&O engineers concentrated on this aspect above all else-It is just total listening enjoyment!
    Then after a few hours of playing and tweeking the speakers to a neutral position things just got better,the way music is presented is just so much more believable and satisfying than before-the detail the lenses deliver is quite amazing and there is even more detail and the bass is just wonderful being much tighter and faster with less extension which was a character of the cabling in the other system.I have fallen into the trap of increasing volume to compensate for the difference in midrange delivery but it is simply different,more realistic and less forward than before.
    I really was expecting to take a step back in sheer musical enjoyment but it appears not,Iam totally chuffed to bits with it considering the outlay.Well done B&O!
    Thanks for listening,hope it made some sense!
  • 05-03-2010 11:09 AM In reply to
    Re: BL9 Impressions):
    great review - thank you for the perspective
    the only bit which did not make sense to me was the phrase "toe in" - at first I thought you had accidentally damaged the the speaker cover !
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 05-03-2010 11:46 AM In reply to
    Good to read this. Yes -  thumbs up Once you have the B&O bug there's no way back! Big Smile
  • 05-03-2010 11:52 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    Great to hear that your a happy with your new setup....I camo from a B&W 802D setup and switched for the same reasons as you described. Iwas tiered to switch and adjust tousends of settings to "hear" music.
    As far as I recall the beworld meeting at Struer we had a discussion with one of the guys there visiting the listining room. All the speaker are setup with a slight "toe in". Reason was quite simple, they started by accident at some time and just did not chanche the way to compare the speakers these days...
    From my point of view the BL9 is with regards to the pricing one of the best speakers in the market....unfortunately not to many hifi experts know that.
    Have fun with yours!
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 05-04-2010 7:45 AM In reply to
    • Teletom
    • Top 500 Contributor
    • Joined on 05-09-2007
    • the Netherlands
    • Posts 111
    • Gold Member
    Quote ".... I wanted them away from the back walls ..... "
    Very good to read your positive impressions about your new BL9's. I have a pair myself and spend quite some time in finding the best possible placing to get a more balanced (higher) midrange character. Initially I was not too happy with the performance in that respect. However stepwise I increased the distance between footprint and back wall from 25 to appr. 60 cm and also followed some suggestions mentioned in a very recent "Beolab9 placement" post on the skandinavian forum. And I must say the improvements in sound quality are just exellent. I am quite happy with the overall performance now.
    Could you give some indication how far your BL9's are placed from the back wall?
  • 05-04-2010 12:46 PM In reply to
    Teletom they are 50cm away from the back wall currently and seem just fine on bass.
    How far apart are yours I have them at just over 6feet?
  • 05-04-2010 3:49 PM In reply to
    • Teletom
    • the Netherlands
    • Posts 111
    • Gold Member
    The distance between the speakers (center-lines) is appr. 2,4 meters; mainly because we have a video cabinet between them.
    best regards
    Johan
  • 05-10-2010 1:14 PM In reply to
    Well,having spent over a week with these amazing speakers-and player Iam totally stunned by the detail,clarity,realism and total enjoyment this system gives you for hour after hour which my previous system did not quite do.
    The BL9/BS9000 beats my old system which was nearly 3 times the price (used) -I was not expecting it to since this was supposed to be a practical change rather than a perfromance one.
    Enough eulogizing for now!
    All the best
