Latest post 05-11-2010 4:55 PM by cozza. 7 replies.
Page 1 of 1 (8 items)
  • 05-02-2010 6:11 AM
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Beotime clock movement
    If anyone has a Beotime with a dead clock movement, the original Junghans ones can still be bought HERE in the UK. Bear in mind that they don't have the small brass nut which secures the minute & hour hands though.
    Chris.
  • 05-02-2010 7:30 AM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    Re: Beotime clock movement
    My Beotime has a dead mechanism, but I think it may be a different model. It has Heichinger stamped on it, and I haven't been able to source a replacement. I wonder if the hands would mount to this one? I'll try to post a pic of it tomorrow, if anyone has any idea where to find one it would be fantastic.
  • 05-02-2010 9:40 AM In reply to
    • Medogsfat
    • Posts 4,045
    Hi cozza, the fittings are standard Euro ones - ie;- the minute hand has an oblique/slotted hole.
    Chris.
  • 05-03-2010 11:41 PM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Perhaps it is the same one?
  • 05-04-2010 7:48 AM In reply to
    • Medogsfat
    • Posts 4,045
    Yep - that's the same.
    Chris.
  • 05-04-2010 4:52 PM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Thanks - thats great! I look foward to getting the beotime back on the wall Big Smile
  • 05-04-2010 6:19 PM In reply to
    • Medogsfat
    • Posts 4,045
    No prob's cozza - let me know if you have any problems with the shipping & I'll gladly send one (or more) on to you. The last time I spoke to the seller he seemed pretty laid back & amenable.
    Chris.
  • 05-11-2010 4:55 PM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Thank you Chris, that's a very kind offer. I'll contact the seller and see if he can post directly to NZ first.
