Hey guys,
Hope some of you can help me with a question.
I have a BV8-40 in the livingroom together with a BeoSound 4 and a MX4002 in the bedroom. All connected with MasterLink. I have for some time now wanted to buy a MacMini as a mediacenter for my setup, and control it with the brilliant LinkPlayer App. But I want to wait for the next generation MacMini, and my fingers are crossed for an HDMI output. Until then, I thought that I would use my MacBook Pro. But how should I connect it? The output connection on the MacBook Pro is the Mini Displayport (MD)
Should I use a 'MD to VGA' and connect it to the VGA port on the BV8-40? I know I only will get max resolution of 1280 x 720, but will it give a good picture?? And will I be able to see the picture on my MX4002 in the Linkroom?
Or should I approach it differently?
Regards, Claus
I was the second place winner on the BeoWorld May 2009 Prize Draw!
Thanks to BeoWorld for a great site!
