Latest post 04-28-2010 4:26 PM by waterlander2004. 8 replies.
Page 1 of 1 (9 items)
  • 04-28-2010 7:17 AM
    Cleaned Penta's stainless steel.
    My Beovox Pentas have always looked very grubby and I decided to give them a spring clean. The original owner must have smoked 60 a day because they were absolutely filthy. Baby wipes just turned a nasty yellow-brown but how ever much I cleaned them the speakers remained stained and horrid. So I tried good old Solvo Autosol and they came up like new. I tried on a tiny portion on the back of the speaker first as Autosol is slightly abrasive and didnt want to ruin the speakers but there was no problem at all. It removed all the dirt very quickly and easily.
    So if you have dirty pentas with stubborn stains, give autosol a go.
  • 04-28-2010 7:19 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Cleaned Penta's stainless steel.
    Fantastic stuff Autosol, been around for years.Yes -  thumbs up
    CraigSmile
  • 04-28-2010 8:25 AM In reply to
    Would this perhaps also work for polishing the metal covers (CD and tape) of a Beocenter 9500?
    September 2009 1st prize winner....
  • 04-28-2010 9:37 AM In reply to
    I've always used a glass cleaner with vinegar + a microfibre cloth. Always works a treat.
  • 04-28-2010 9:49 AM In reply to
    j0hnbarker:
    Trust me I tried! This was an impenetrable layer of yellow-brown nicotine. Not nice at all.
  • 04-28-2010 10:01 AM In reply to
    beaker:
    j0hnbarker:
    Sounds like you needed shot-blasting!
  • 04-28-2010 11:24 AM In reply to
    I've always thought that it is the people who smoke inside that need shot-blasting Angry
    -mika
  • 04-28-2010 1:07 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    waterlander2004:
    NO - never use anything even mildly abrasive on these mirrored anodised aluminium panels. If they are scuffed then that is how they will stay I'm afarid. Any attempt to remove anything other than surface grime will ruin them & the more you do the worse they will look. This also applies to the panels on the 4500 system.
    Penta's have stainless steel panels with no surace treatment other than the factory polish which is why this type of prodcut is perfectly safe to use on them.
    Chris.
  • 04-28-2010 4:26 PM In reply to
    Thanks Chris,
    That is good advice... I am glad I didn't try it!
    Kind regards, Eric
