Latest post 04-28-2010 9:44 AM by Andy . 3 replies.
Page 1 of 1 (4 items)
  • 04-27-2010 3:43 PM
    Beocenter 9500 bottom glass plate
    Looking for a Beocenter 9500 bottom glass plate (with the plastic mounting frame)...
    I recently acquired a unit in otherwise good condition but with a tiny chip off the bottom glass. If anyone has a spare glass plate (in good condition, including the control elements on the underside) they are willing to let go, please drop me a PM.
    Thank you, kind regards, Eric
    September 2009 1st prize winner....
    Filed under:
  • 04-27-2010 4:09 PM In reply to
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    Re: Beocenter 9500 bottom glass plate
    Hi
    I have both glass plates top and bottom and the frames i think they are pretty good condition but will check. What are the control elements??
  • 04-28-2010 4:17 AM In reply to
    I'm not sure whether that is the right term, but as I understand it there are small conductive pads (or tracks?) underneath the surface of the glass (on the underside), to which the unit is applying a high frequency signal in order to detect whether the user is touching the glass at that point. If the glass is undamaged they should be fine. Let me know how they look!
  • 04-28-2010 9:44 AM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Hi
    yes all intact still has the old glue around the edges so would need removing.
    Andy
