Latest post 05-17-2010 2:07 PM by Craig. 4 replies.
Page 1 of 1 (5 items)
  • 04-26-2010 6:37 AM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beogram 1000 - Motor overhaul
    How easy si it to strip clean and rebuild a BG1000 motor. Got a lovely mint one with the usual slow speed issue. Left in running for 30 mins, and now its playing fine. Just listened to William Orbit on it. In the past I have done a BG12XX with no problem at all. Although I know this motor is quite different, I imagine the fault to be the same. Dried up grease. Which is now doing the opposite of what it should.Laughing
    CraigSmile
  • 04-26-2010 10:06 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1000 - Motor overhaul
    The Beogram 1000 came with 4 different motors.
    Some are easier than others.
    The main problem is usually the motor pulley, some are incredibly
    tight on the spindles, especially on the old round motor type.
  • 04-26-2010 1:40 PM In reply to
    • Craig
    • Posts 4,855
    Dillen:
    DOH!!!! LaughingLaughing
    Strangely when I removed the bottom cover. There was another of the small PCB's that fit in place of the RIAA floating about.
    Looks like I will have to remove the motor and see how it goes. Think this may be a job to do when I have got my vice sorted out. Not sure where it is packed at the moment.
    CraigSmile
  • 04-26-2010 4:17 PM In reply to
    • Dillen
    • Posts 5,008
    Yes, that's the one...  Laughing
  • 05-17-2010 2:07 PM In reply to
    • Craig
    • Posts 4,855
    Is it possible to change the motor for a different type? Just picked up a new old stock one. Part number 8400042. It's the same type s used in the BG1203.
    CraigSmile
