If DTV is bringing up SKY then the DVB option is turned off.
There are some uses to turning it back on, and turning off the (analogue) TV option instead, allowing you to allocate Sky to the TV button.
If you are ever recording two programmes off of SKY (which my wife frequently does), then you can switch to the in-built digital terrestrial tuner via the DTV button (once you have turned it back on in the Tuner Options MENU).
DVB-HD - my understanding is - is a bit misleading in the UK, it is a Euro only benefit and will require both hardware and software changes to work in the UK - best choose it without this option if purchasing new and buy a decent FREESAT HD PVR!
