Latest post 04-26-2010 3:28 AM by Andy . 6 replies.
Page 1 of 1 (7 items)
  • 04-25-2010 6:52 AM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    AV9000 and Beo4 video aux
    Hi
    I have become a proud owner of a lovely AV 9000 for my bedroom. It is connected with Beolab 6000s. I also have  roku soundbridge which I have connected to the video aux source at the back of control centre. I can select it by selecting the auxillary menu from the tape menu on screen but just wondered if I could select it directly form the beo4 I have added V aux to the list menu but it doesnt seem to work??
    Any ideas of how and if this can be done??
    Many thanks
    Andy
  • 04-25-2010 7:40 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: AV9000 and Beo4 video aux
    Andy, do you mean the component connections? Red, White and Yellow phono (RCA) conections. If so then you need to add either Camera or Camcorder depending on the age of your Beo4.
    CraigSmile
  • 04-25-2010 4:26 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Hi craig
    yes the component connection ive connected the audio L and R works great if manually select it but doesnt work through camcorder function when I add it? Any other ideas? Or is it just a manual thing?
    Thanks again \\
    Andy
  • 04-25-2010 4:44 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    try (corresponding to the version of your Beo4 and your AV9009) following sequence:
    "V.Taqe/V.Mem" ; "Menu" ; "5" ; "5"
    if "5" is the guide number for the "V.Tape" in the main menu and then,
    inside the tape menu,
    "5" should be the guide number for "V.Aux" again
  • 04-25-2010 5:20 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Hi
    thanks but I dont understand what i have to do very amateur when it comes to this!
  • 04-25-2010 5:59 PM In reply to
    • Vienna
    • Posts 712
    Hi Andy,
    it's the same you did "manually" - just using shortcuts and beeing the fastest way to get "V.Aux"
    There is no direct way to "V.Aux" - those days in 1992 the only use for "V.Aux" was
    copying from a camcorder to the VCR ...
    Your way:
    started by pushed "TV" or "V.Tape/V.Mem"
    then "Menu"
    then 4 times "Arrow down" to highlight "V-Tape Menu"
    then "GO"
    then 4 times "Arrow down" to highlight "V.Aux"
    then "GO"
    to get "V.AUX"
    (this way takes + 10 seconds)
    The same happens, if you press the following buttons in short intervals
    ! The number at the beginning of each menu line can be used as a shortcut !
    (As far as I can remember, in the main menu "V-Tape" is  the 5th line
    and in the V-Tape menu  "Video Aux" is the 5th line again)
    press "TV" or "V.Tape/V.Mem" ;
    press "Menu"
    press "5"
    press "5" again
    (taking only 2 or 3 seconds to reach the target)
  • 04-26-2010 3:28 AM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Brilliant worked a treat and if I press AV first the TV remains closed. As my wife said its a very complicated way to get music......... but I dont care!!
    Thanks again
