cfeaver: I can get TV DTV but not DTV
Do you mean that you get the old analogue channels ?
And you friend lost your newer digital channels ?
Are these "free to air" digital channels, or are the channels that you use a set top box or cable box for ?
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
