Latest post 04-25-2010 5:12 AM by whiteflock. 2 replies.
Page 1 of 1 (3 items)
  • 04-24-2010 5:36 AM
    B&O Beogram 2402 Record Player
    Firstly I am new to the world of B&O, so forgive my ignorance. I have recently (actually over a year ago) inherited a B&O Beogram 2402 Record player, and want to get it working to listen to some of my grandad's records, unfortuntately the stylus seems to be completely missing. Naturally I started searching the internet for a replacement stylus and they seem to be rather expensive. FYI the turntable originally comes with a MMC 20EN Cartridge. So my questions are as follows:
    1. Can non B&O stylus' be used with this turntable?
    2. If not can non B&O cartridges be used with this turntable?
    3. If not can other B&O cartridges be used, such as the MMC 20S?
    4. Where is the best place to buy such things?
    I am a student the cost is of paramount importance at the moment, thanks.
    Alan
  • 04-24-2010 6:56 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: B&O Beogram 2402 Record Player
    Hi Alan - welcome to BeoworldSmile
    1. No - the cartridge/stylus is an integrated unit.
    2. No.
    3. Yes - any of the MMC20 range will fit (also the MMC10E). The MMC3000 to 6000 range will fit but these will be very old & probably have shot suspension. The MMC1 to MMC5 range will NOT fit as they have totally different connections - pins as opposed to a spade.
    4. The only real place I would recommend for new cartridges is www.sound-smith.com in the USA. They aren't cheap though but are brilliiant & hand built. You could also get your original cartridge rebuilt by Axel in Germany (send an email - his English is excellent apparently) but again not cheap on student wages. This will also depend on whether all channels are working - if not then it is only fit for the bin I'm afraid.
    Of course there is always ebay but I wouldn't personally recommend this as they are all aged now & even so called NOS (new old stock) ones are likely to fail due to hardened suspension.
    Chris.
  • 04-25-2010 5:12 AM In reply to
    Thanks for the warm welcome and comprehensive answer Chris, you have solved all my queries in one swipe. I'll take your advice and steer clear of ebay for a new cartridge/stylus and check out  www.sound-smith.com.
    Again, thanks for all your help.
    Alan.
