Latest post 04-23-2010 6:10 AM by xegoon. 3 replies.
Page 1 of 1 (4 items)
  • 04-22-2010 1:47 PM
    Connecting a Sub to Beovision 10
    Is it possible to connect a subwoofer to a Beovision 10, and only use the internal speakers for stereo sound?
    /C
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 04-22-2010 2:36 PM In reply to
    Re: Connecting a Sub to Beovision 10
    Hiort:
    /C
    Yes, using the sub connection on the BV10, infact you will be able to see set ups like this at the B&O stores soon Wink
    Jq. BS4 BL3 A8 Form2
  • 04-23-2010 3:21 AM In reply to
    Thx. The configuration is not shown in the manual i downloaded, hence my question.
    I assume you mean BV10 and the Beolab 11 when you refer to the B&O store setup.
    /C
    _____________
  • 04-23-2010 6:10 AM In reply to
    Hiort:
    (...)I assume you mean BV10 and the Beolab 11 when you refer to the B&O store setup.
    /C
    You're right Yes -  thumbs up
