Latest post 05-19-2010 2:30 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 04-19-2010 11:46 PM
    BEO5 XML file for Pioneer DVR-550
    Hi there
    I am after the codes to control a Pioneer DVR-550 (DVD player/recorder). I have tried the Pioneer Dv646 codes in BeoWise downloads section but they dont work... Not sure if someone has created codes already that will work???
  • 05-19-2010 2:30 AM In reply to
    Re: BEO5 XML file for Pioneer DVR-550
    I do not have an XML file for the Pioneer DVR-550 and as with most Pioneer produce products they use a modified NEC protocol. As the protocol allows for 256 device codes, its often the case that a different code is assigned to different products of the same manufacturer, hence why the DV646 XML file did not work.
    Your options are:-
    1. Capture the codes from your existing remote and either make an XML file with the Beoworld XML Generator yourself or get it made for you.
    2. Find on the web Philips Pronto HEX file (not ccf files) for the product which can then be converted to an XML file. The best place to start looking for Pronto HEX codes is HERE
    3. Contact Pioneer support who are usually most helpful in providing a code sheet for their products. For Pioneer you just need teh HEX device code and the code for each command
    Regards Keith....
