1st March February 2012
Latest post 11-24-2010 5:18 AM by futurist. 9 replies.
04-19-2010 9:30 AM
BeoGreg
- Joined on 07-24-2008
- South of France
- Posts 139
On the back of my BV10-40...
A picture says it all !
Gregory
Since 1995 : Beosound Century, Beolink 1000, Beocom 2400, Beovision MX 6000, Beocord VX 7000, Beo 4, LC2, Beosound Ouverture, Beolab 2500, Beocom 6000, Beolab 8000, Beosound 9000, Beovision Avant 32, Keyring, Bottle opener, Beosound 2, A8, Beosound 3, Beovision 10-40, Beo 4 Navigation, BeoTime, Beocom 5, Form 2...
Hiort
- Joined on 04-17-2007
- Posts 383
Re: On the back of my BV10-40...
Wow.... You really managed to pack loads of stuff there...
What does it look like from the front? Completely hidden, I assume.
I just ordered my BV10 40" from my dealer, to replace my BV8 32". The BV10 will be mounted on the wall with the bracket that can swing out 45 degrees.
Will keep all my stuff in a sleek bench underneath.
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
malcolm welborn
- lanzarote canary islands
- Posts 180
engineer coming next week to fit stb bracket for hd dig box
so should be hidden
malcolm
BeoGreg
- South of France
- Posts 139
Hiort:
This is the front. The Horror of the back is not visible of course.
Gregory
Hiort
- Posts 383
Very nice! Nice with the blue speaker cloth, matching the carpet.
_____________
redil
- Joined on 11-22-2010
- Posts 9
Hiort
I also need to stow away stuff, actually a reelbox which is way bigger that the dreambox on that photo. Thus, I also need a 'bench', what did you get?
Hiort
- Posts 383
redil:
Hiort
I got the bench on the photo. Bought in a store in Stockholm. Its glossy white and hide a Cable HD PVR box, Bluray and a TVIX media player.
_____________
futurist
- Posts 171
Hi Hiort
What have you used to conceal the cables between the bench and the TV?
Cheers
Stuart
Hiort
- Posts 383
futurist:
Hi Hiort
Cheers
Stuart
Just a simple "cable channel" that I think you can buy at any "handyman shop". It had to be a little wider than I wanted, since I needed to fit a component cable in there. Works well.
Cheers
Claes
_____________
futurist
- Posts 171
Thanks - will have to investigate.
Page 1 of 1 (10 items)
